Zenblak
Jan 04, 2021Aspirant
Nighthawk R6700v3 Speed Issues
I bought a Nighthawk R6700v3 last summer and I have not been able to get the speeds that I am paying for. Currently I am paying for 1Gb download from Cox using a Modem/router device that they su...
Decreet
Nov 24, 2021Aspirant
I have the same problem. What firmware did you downgrade from? I need to do the same.
Nov 24, 2021Guru - Experienced User
What Fw version are you using?
Since the OP first posted this, they were on v106.
I see v118 and v120 thats most corrent:
https://www.netgear.com/support/product/R6700v3#download
If v106, try v102 or something prior to v106.
