Zenblak
Jan 04, 2021Aspirant
Nighthawk R6700v3 Speed Issues
I bought a Nighthawk R6700v3 last summer and I have not been able to get the speeds that I am paying for. Currently I am paying for 1Gb download from Cox using a Modem/router device that they su...
dpmoore
Feb 10, 2022Star
I see others have the same issue. I have been capped to ~200Mb/s (Wired) for sometime now. Just have not had the time to troubleshoot. I have the Xifinity 1300Mbps package
Modem CM1000V2
R6700v3 Firmware: just updated to v1.0.4.122
Nighthawk_f
Feb 28, 2022Aspirant
I have the exact same equipments with the exact same problem. I'm paying for 900mbps but some how speed cannot get over 250. I tried downgrading (doesn't work), i tried everything in these forums, nothing works. At this point I'm thinking about switching to another brand.
- plemansFeb 28, 2022Guru - Experienced User
Nighthawk_f Have you started your own thread? We highly recommend that so your info isn't confused with the OP's.
And include all your info, not just "having the same problem". Include your setup, what you've tried, and any other details you can think of.
