icadar
Jan 23, 2023Follower
Nighthawk R6700v3 support fiber ?
Nighthawk R6700v3 Firmware Version V1.0.4.128_10.0.10 Windows 10 , ROKU Youtube TV , iOS phones Just moved and have Spectrum Fiber installed ,, using Spectrum Fiber modem and my Nighthawk rout...
michaelkenward
Jan 23, 2023Guru - Experienced User
icadar wrote:
I have tried all the typical tasks without any luck,,,,
Did that include a rest for your router?
You need it to forget its settings from your previous network.
As plemans says, there is no reason why a router shouldn't work with any Internet service, With fibre it is often just a case of plugging the WAN port from the router into the LAN port on your fibre connection.
Experiencing Slow internet connect to urls via iphones ,,, elongated connecting from Smart TV/Roku ,, Netflix/Youtube TV,,,,
It sounds like the thing is working. So, back to that reset.
