Hammit
Mar 07, 2025Aspirant
Nighthawk R6700v3
New Here Noob questions: I have a router I've been using for basic internet for a while now. Just upgraded to 1 Gig fiberoptic internet but the speeds are not going up except for Upload speed. Looking...
- Mar 07, 2025Hey Furrye38:
Thanks for the science. Didn't expect a reply since all these posts were from 3 years ago! I reset the router and have 350-500 mbps so that's an improvement until I new hardware on board. Cheers and thanks again ~ H
Mar 07, 2025Guru - Experienced User
Those are connection rates between the router and a device. Actual bandwidth speeds differ from connection rates.
Basied on router design and connected device design, most you'll ever see is around 300- maybe 500Mpbs on 5Ghz AC. You should seen near 900Mbps on ethernet.
If you want to see near that on wifi you'll need a different router.
Also most wifi devices are 2x2 MIMO so this also limits speeds as well. 4x4 MIMO would see near 1Gb or over. WIth newer generation routers.
- HammitMar 07, 2025AspirantHey Furrye38:
Thanks for the science. Didn't expect a reply since all these posts were from 3 years ago! I reset the router and have 350-500 mbps so that's an improvement until I new hardware on board. Cheers and thanks again ~ H- FURRYe38Apr 13, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
