Stanlhui
Apr 18, 2019Aspirant
Nighthawk R6850: can't log onto Apple app store
Hello
I have a nighthawk R6850 - macos Mojave (couldn't find it from the dropdown list above :-( ). Two issues occurred:
1. After updated firmware v1.1.0.54, I can't log onto Apple's app stor...
- Apr 19, 2019
Have you tried to roll back the firmware and then check if you are still seeing the same issues?
DarrenM
Stanlhui
Apr 20, 2019Aspirant
Rolled firmware back to V1.1.0.52. Now it works fine to access Apple's app store. Thanks
schumaku
Apr 21, 2019Guru - Experienced User
ChristineT Christian_R more router bugware - take action or create a "roll back to the previous firmware" KB entry for this ****.
- myerswApr 21, 2019Master
Maybe Netgear needs to fire all current engineers and start over. It seems like the current group, in house or out sourced to not have the capability to fix on going issues.
DarrenM ChristineT @Christian_R
Is it possible to get a statement from Netgear regarding the firmware engineers. Some folks say in house, and some say they are 3rd party outsourced. Inquiring minds want to know.
