lakhbir75phd
Aug 14, 2021Follower
Nighthawk r6900 activation
I just bought a used netgear nighthawk R6900 Dual Band router and as i go to set it up, i get a error while registering the product which is that its already been registered. This is a dissapointment...
antinode
Aug 14, 2021Guru
> Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Which is it? Look for "Model" on the product label.
What's to "activate"? What benefits do you expect to get from
registering this out-of-warranty device?
> [...] i get a error while registering the product which is that its
> already been registered. [...]
Complain to the seller? Or:
