lakhbir75phd
Aug 14, 2021Follower
Nighthawk r6900 activation
I just bought a used netgear nighthawk R6900 Dual Band router and as i go to set it up, i get a error while registering the product which is that its already been registered. This is a dissapointment...
michaelkenward
Aug 15, 2021Guru - Experienced User
That's right. The first user probably registered it.
Registration is of limited value and does nothing to prevent you from using the thing. It exists for free installation support (90 days after purchase) and warranty protection (a year or so depending on where you bought it.)
Neither of these is transferable to another user.
lakhbir75phd wrote:
This is a dissapointment after buying a product and trying to set it up at home.
Why a disappointment? It is a fact of second-hand life – hope you got a bargain – that does not prevent you from using the thing.
First, of course, reset the device to remove any settings created by the previous owner.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
If you are talking about something else, such as signing up for Anywhere Access on mynetgear, which isn't really a registration issue, try this:
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
