aadman's avatar
aadman
Nighthawk R6900 Internet Access Only Wired
Hello folks, I have had a R6900 for a few months now and have had no issues but on the past couple days I have been having a strange problem, I can connect to the wireless networks and have strong si...
  • aadman's avatar
    aadman
    Oct 07, 2016
    Got it figured out. The comcast modem/router that I had set in bridge mode was going crazy and would turn its wifi on, every time that happened the Nighthawk wifi would lose internet, I do not know why.
    The solution:
    1- Turn everything off
    2- Reset comcast modem/router to factory
    3- Reset comcast modem/router to bridge
    4- Turn Nighthawk back on
    All working.
    Thanks for the help.
    Andre
