normshige
Jul 05, 2017Aspirant
Nighthawk R6900 Internet Access Only Wired
I have had the R6900 almost a year and have not had any problems with it. I was going to upgrade the firmware on it so I turned it upside down to get the model number of it. Now the WIFI does not w...
- Jul 06, 2017
You may have inadvertently pressed the physical Wi-Fi On/Off button. Try pressing it again.
If that doesn't help, try a factory reset. There's an option to erase all settings in the menus. Alternatively, press and hold the physical reset button for about 8 to 10 seconds, release after all lights flash on and off.
TheEther
Jul 06, 2017Guru
normshige
Jul 06, 2017Aspirant
OMG!!!!
Thanks, I didnt realize that there was a on/off switch there. I had an idea it would have been something stupid like that.
Thanks again!
