Jimd47
Sep 24, 2016Aspirant
Nighthawk R6900 won't work with older laptop
My R6900 will not work wireless with an old Compaq Presario but works wireless with my Sony Viao and apple products. Can rhe R6900 be configured to work with older laptops? Everything worked well...
- Retired_MemberSep 25, 2016
Jimd47 wrote:
"WPA-PSK [TKIP] + WPA2- PSK [AES
yes
Jimd47
Sep 25, 2016Aspirant
Yes, I had it working wireless on a Belkin54G N router before it went south. The laptop see the wireless network but when I try to connect it says it connects there is a red "?" On the wireless connection. If I connect to the router via cat5 I can connect and get online so the issue is with only the wireless. If I try to repair the connection I get "Windows is unable to find a certificate to log you onto the network". I do not have a certificate on any other units and only use a password on the router.
Retired_Member
Sep 25, 2016re-read post 3
use the circled in red security
