spyder99
Jun 08, 2021Aspirant
Nighthawk R6900P configure in bridge mode
I just bought a nighthawk R6900P wifi router as the description said it would do wireless bridge mode or some times called client mode. Here is a basic diagram of how it would be connected: FW-route...
antinode
Jun 09, 2021Guru
> FW-router -- unifi switch -- unifi AP --wireless_connection-- R6900P
> -- internal net
Where "internal net" means devices connected to the LAN Ethernet
ports of the R6900P-as-bridge? Other devices can connect to "unifi AP"?
> [...] I can no longer connect to the device via ethernet or wifi for
> that matter.
Connecting by Wi-Fi is out of the question if it's in bridge mode;
its wireless stuff would be dedicated to its link to the main
router/WAP.
"can no longer" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Does the R6900P-as-bridge get connected to the main LAN? Does it
appear in some kind of Attached Devices or DHCP Clients report on the
main router/WAP?
Do (wired) devices which are connected to the R6900P-as bridge get
valid IP configurations (from the DHCP server, wherever it is)?
> Basically, I need [...]
That's what bridge mode should do.
> Oh, the R6900P is running the latest firmware.
As always, an actual version number would be more useful than your
opinion of what's "latest" today.
spyder99
Jun 09, 2021Aspirant
Ok, let me expand a little bit more then.
antinode wrote:> FW-router -- unifi switch -- unifi AP --wireless_connection-- R6900P
> -- internal net
Correct... "internal net" means the devices connected to the Etherenet LAN ports on the R6900P when in bridge mode. Any other devices can connect to the "unifi AP."
> that matter.
>router/WAP.
Correct, connecting via WiFi is not going to work. Here is what I mean: I can see from my DHCP server that the R6900P in bridge mode did receive an IP address from the wireless link to the main network. However, it's not even responding to pings on that IP etc. So, can't connect to manage it that way. Also, a device connected to the LAN ethernet port on the R6900P do not receive an IP address. I've tried manually setting the address to the typical subnets used by netgear i.e. 192.168.0.1, 192.168.1.1 and 10.0.0.1, but have no success connecting to the R6900P. Sorry for the vague "can no longer connect," but the above is what I meant, by that.
As for what I did. I followed the instructions for setting up the router in bridge mode from the R6900P documentation. Once that was done, I could not connect to the R6900P as mentioned above. So, no additional command/actions could be done. LED indicators are as follows: white power light, white 5ghz light, flashing white LED on LAN port 1 where the external device is plugged into, white WiFi on light and white WPS light.
>main router/WAP?
As mentioned above, it gets an IP from the DHCP server, but nothing responds on that address. A scan of that IP returns that there is no host there.
Wired devices do not get an ip address at all. Just a self-assigned IP. Should the R6900P assign an address to these LAN port devices or is that to come from the main network DHCP?
The firmware is: 1.3.2.134_10.1.66
Hopefully the additional information helps.
- antinodeJun 09, 2021Guru
> [...] I can see from my DHCP server that the R6900P in bridge mode did
> receive an IP address from the wireless link to the main network. [...]Ok. That's a start.
> [...] However, it's not even responding to pings on that IP [address]
etc. [...]See "not a useful problem description [...]", above. "ping" from
where? Actual error message? There's no good reason to hide private
IP addresses. What should "etc." tell me?> [...] I've tried manually setting the address [...]
Of what? How?
> [...] Should the R6900P assign an address to these LAN port devices or
As a "bridge", it should be too stupid to do anything except provide
a comm path; the DHCP server on the main LAN should do any DHCP work.It sounds as if wireless-bridge mode on this thing is not working,
even though it did seem to get connected to the main LAN. I don't have
an R6900P, so I can't verify anything. Knowing nothing, I might try a
different/older firmware version (or two) to see if it's a new
(firmware-related) problem. I'd also try the usual desperation move, a
settings reset, but I wouldn't expect it to help.
