traktroy360
Feb 20, 2021Follower
Nighthawk R6900P won't connect to internet
I moved to a new apartment and plugged in my modem and router and everything came up fine as normal. Then it stopped connecting to the router and would only connect to the modem. I have tried resetin...
michaelkenward
Feb 21, 2021Guru - Experienced User
Bit hard to understand what is going on here.
What is this modem?
traktroy360 wrote:
It has two white lights on (The power and Internet lights) but nothing else.
That looks right. So what tells you that there is no Internet connection?
If the wifi lights are off, try pressing the wifi on/off switch on the top.
traktroy360 wrote:
Modem is not in bridgemode.
Why not? If it is a modem/router it probably should be.
