JimTheolet
May 12, 2022Follower
Nighthawk R6900P
I recently had a problem with my router not connecting to the internet so after unplugging and restarting, I decided to reset the router not knowing that it would erase the id and password and do a c...
May 12, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
