jagged
Aug 04, 2023Aspirant
Nighthawk R6900v2 antenna loose
I have a Nighthawk R6900v2 router. It has been mishandled, and one of the antennas has come apart. See attached photo. The screw connector mounted on the motherboard is just fine and is solid. It's ...
Aug 04, 2023Guru - Experienced User
Ya might try glue but know once glued it.
Could find a alternative replacement online if that unscrews from the router?
