jagged
Aug 04, 2023Aspirant
Nighthawk R6900v2 antenna loose
I have a Nighthawk R6900v2 router. It has been mishandled, and one of the antennas has come apart. See attached photo. The screw connector mounted on the motherboard is just fine and is solid. It's ...
jagged
Aug 14, 2023Aspirant
I don't really know which part has broken or come apart. I also don't know which part needs to swivel (or not). There doesn't seem to be any broken plastic or glue anywhere. Does the knurled knob have to turn relative to the part that it comes up against? If so, then how does it stay together?
