Cedric2x7
Jun 10, 2021Aspirant
Nighthawk R700/ 1 Gigabyte
I’ve had this route for about a year now. I had Comcast cable and had 1 gig but would average around 300mbs. I recently moved to Myrtle Beach, South Carolina and paid for fiber optic gigabyte inter...
Jun 10, 2021Guru - Experienced User
What actual gateway is it?
Did you try a factory reset on the r7000?
Try that and during the install, don't use a backup configuration. Also, make sure to leave qos, access controls, traffic monitoring, and parental controls disabled.
Cedric2x7
Im not sure what gateway it’s on. I did a factory reset a few hours ago and I’m still getting very low speeds.
I made sure all the fluff like QOS is off yet it won’t even hit 300mbs.
