Lagge
Jan 12, 2022Guide
Nighthawk R700 AC1900 halbe Download Geschwindigkeit
Guten Tag, habe leider folgendes Problem. Mein Aufbau: Vodafone-Box Nighthawk Switch GS105Ev2 / Switch GS108Ev3 An der Vodafon-Box kommen laut Vodafone 577 mbits Do...
- Jan 12, 2022
the R7000 was released in 2013. Its a 9 year old router. It didn't have the processing power to hit gigabit speeds so it had to use cut through forwarding. Sadly when you use qos/access control/traffic monitoring/parental controls, it disables cut through forwarding. It limits the speeds to around that 200-300mbps. And every once in a while disabling those service and rebooting doesn't re-enable cut through forwarding. a factory reset can re-enable it.
Lagge
Jan 12, 2022Guide
Firmware = 1.0.11. 130
access control, traffic monitoring, parental controls, and qos is off.
I restarted the router.
But the download is still low.
Jan 12, 2022Guru - Experienced User
If you put the vodafone back in router mode and put the netgear in access point mode, how are speed?
It wouldn't be the first ISP modem that didn't funciton properly in bridge/passthrough mode.
