Lagge's avatar
Lagge
Guide
Jan 12, 2022
Nighthawk R700 AC1900 halbe Download Geschwindigkeit
Guten Tag,   habe leider folgendes Problem. Mein Aufbau:   Vodafone-Box Nighthawk Switch GS105Ev2  / Switch GS108Ev3   An der Vodafon-Box kommen laut Vodafone 577 mbits Do...
  • plemans's avatar
    Jan 12, 2022
    the R7000 was released in 2013. Its a 9 year old router. It didn't have the processing power to hit gigabit speeds so it had to use cut through forwarding. Sadly when you use qos/access control/traffic monitoring/parental controls, it disables cut through forwarding. It limits the speeds to around that 200-300mbps. And every once in a while disabling those service and rebooting doesn't re-enable cut through forwarding. a factory reset can re-enable it.
