ChrissyH
Jun 29, 2017Tutor
Nighthawk R7000 -- WIRELESS speeds FASTER than wired speeds
Weird problem I cannot figure out on my own - I am hoping someone can point me in the right direction. All wired connections have a download speed of 10-11 Mbps. This includes my desktop compute...
- Jul 04, 2017
I was able to fix my problem by accident.
I was looking through these forums for people that had the same issue or something close to it and I saw someone said they had QoS checked off and when he clicked it off, the wired speed went back to normal (fast)
I checked, and my QoS box was unchecked, but I noticed on the screen there was a speed test button. I clicked it and it showed my speed was 104 Mbps even though minutes before that, my Ookla speed test on their site was 11 Mbps. Very very weird.
Anyway, you can try that and see if it works for you. To get there:
1. Go into your settings and login by typing in 192.168.1.1 in your browser window.
2. Under basic, click home
3. I had 6 boxes, one is called Attached Devices. It showed the number of my devices and also showed QoS: Off
Click on QoS: Off to go into QoS settings
4. I made sure the enable QoS box was unchecked
5. I then clicked on the speed test button
6. Once finished, click on the green apply button
That was pretty much it. Hope it helps. I am still not sure how my settings became messed up in the first place.
SillyMan
Jul 17, 2017Aspirant
Hey I've been having similar issues. I just made a post about it but recently my wired connection has been horrible using QoS. I tried to dynamic QoS and it helped initially but now my upload is bad. Initially dynamic was working fine but now it's just horrible and went back to my advanced settings. Looks like I'm just going to turn QoS completely off. It must be a recent firmware update that made it worse.
bhanlon
Aug 13, 2017Initiate
WOW, I can confrim that Chrissy's solution is indeed correct. I turned off QOS and now my download speeds are what they should be when wired.
This is VERY unfortunate and i'm hoping is caused by a firmware update. The whole reason i bought this router was for the QOS features to use with gaming. Now i cant use them. It seems very strange that a QOS setting for upload throughput is affecting only download speeds when wired. I hope this gets fixed soon in a firmware update.
