EDarga
Jun 17, 2017Aspirant
Nighthawk R7000 - Block incoming IP address OR How to block SIP Scanners
We use FreedomPop, but it could be any VOIP service. One phone has been getting calls almost "non-stop" for several days, when the phone is set on wifi service. They are from non-standard phone ...
- Jun 22, 2017
Hi William10a,
That is correct. Other services that uses this port will be blocked as well but only on the specific device since you can enter the IP address of the device.
William10a
Jun 20, 2017Master
Yes the can be block what any other services that may be running on that port would not they be stop also ?
JamesGL
Jun 22, 2017NETGEAR Employee Retired
Hi William10a,
