MagnusTh
Oct 20, 2017Aspirant
Nighthawk R7000 - Block incoming IP address OR How to block SIP Scanners
Using a AXIS A8105-E Door station as a VOIP doorbell with Linphone SIP configured both on the AXIS unit and on a Mobil phone with Zoiper app, use to work before I updated to the new SW V1.0.9.12_1.2....
- Oct 27, 2017
Solution, changes the RTP start port from 4000 to 40000 on the Axis unit, and on the R7000 deactivate SIP ALG under NAT-filer and leave it "Open" box checked in.
JamesGL
Oct 26, 2017NETGEAR Employee Retired
Hi MagnusTh,
Can you check with the AXIS or the linphone SIP if there are settings needs to be done with the router.
- MagnusThOct 27, 2017Aspirant
