cgwzam
Jul 21, 2021Aspirant
Nighthawk R7000 - drops internet to phones only
This has been happening for a couple months, but has recently started becoming too frequent. The internet will stay connected to most devices in our home, but will drop to our phones. Our security ca...
Jul 21, 2021Guru - Experienced User
1. what modem/gateway is it connected to?
2. what firmware is on the router? (please don't say the latest)
3. when it happens, are the devices saying "connected, no internet", are they disconnecting from wifi entirely, what is actually happening?
- cgwzamJul 21, 2021Aspirant
It is a Netgear modem CM1100 - the modem is working just fine.
Firmware is 1.0.9.88 - I know this is not the latest, but Nighthawk app says no newer available.
Devices say connected, no internet.
I can always log into the router via anywhere access in the app, even when my wife at home says it is not working while I am at work, so I know it is not the modem. The router worked flawlessly for about 3 months, then this issue started happening about once a week. Now it is every couple hours.
- plemansJul 21, 2021Guru - Experienced User
You can manually update to the 1.0.11.123 version thats out.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
then try a factory reset and reinstall
Thanks for your help! Forgive my ignorance, but is there a way to update the firmware without a working computer with an ethernet port? My wife's laptop doesn't have one, and the motherboard went out on mine recently. Or will it work to update to 1.0.11.123 via the routerlogin page?
