KenH999
Jun 24, 2021Aspirant
Nighthawk R7000 - Factory Reset Questions
I'm having annoying frequent WiFi issues. The router just drops all WiFi at times. Internet and wired devices remain OK. Nothing at all shows up in the logs so it's useless. Bought it new Nov. 2020 s...
antinode
Jun 24, 2021Guru
> [...] Is there some reason I should not update?
Not all Netgear firmware versions are trouble-free. However,
although you can read reports in places like this, running the
experiment may be the only reliable way to see if the newer bugs are
better (for you) than the older bugs.
> If I do update, will the Hot Fix (V1.0.11.123_10.2.100) bring the
> firmware totally up to date [...]
It should. Generally, a "Hot Fix" is a complete firmware kit,
lacking only the confidence of the people who provide it.
> BTW, I don't suppose there is a setting anywhere that allows
> increasing the login timeout period? [...]
I know of none. Tell your browser to save the credentials?
KenH999
Finished the reset. Manually re-set all the various settings vs. using a saved config file. During the reset it checked for a firmware update but said NO updates available. Huh? Is this normal? Ignore it and update anyway?
Why would the device not see updates are available?
Ken
- Portwey84Jun 24, 2021Virtuoso
KenH999 wrote:Finished the reset. Manually re-set all the various settings vs. using a saved config file. During the reset it checked for a firmware update but said NO updates available. Huh? Is this normal? Ignore it and update anyway?
Ken
Don't get hung up about auto updates. You are better off manually checking yourself by just Googling R7000 firmware updates and it will take you to the Netgear download page for the model. I check monthly. I've done six firmware updates since buying my own router in February 2020 all problem free.
- KenH999Jun 25, 2021Aspirant
Thanks. I was going to do the update this afternoon after wife finishes work (remote worker) but apparently it auto-updated overnight. So far everything works. Sure hope the reset and/or update solves the WiFi issues.
I call this issue resolved.
