beglovent
Jan 21, 2017Aspirant
Nighthawk R7000 - Fritz Fernzugang geht seit Routerwechsel nicht mehr
Liebe Community, ich habe ein Problem bzgl. des Verbindens via VPN zu dem Netzwerk meiner Firma. Ich habe zu Weihnachten einen meinen neuen Router Nighthawk R7000 bekommen. Dieser ist hinter ...
- Jan 23, 2017
Sooo... My provider changed my public IP back to an IPv4 address et voilá - it's working again. Problem solved. Thanks for my reading my monologue :smileywink:
LeeH
Jan 21, 2017Prodigy
English Translation:
Love community,
I have a problem regarding the connection via VPN to the network of my company.
I have a christmas for my new router Nighthawk R7000 get. This is connected behind a cable modem from Vodafone. I have now the problem that the already configured and before the old router D-LINK DIR-615 functioning VPN access via Fritz remote access no longer works.
I have tested how it behaves when I take my mobile as a mobile hotspot, result: VPN access works. That means in the reverse, that the problem lies in my LAN and then remains then only the router is left.
However, I would like to briefly note that I have also received a new cable modem, since I changed from a 100 to a 200er line, but do not assume that the cable modem plays here a role.
What I have done so far: NAT type on open, port forwarding for ports 500, 1701 and 1723 set, VPN service in the router activated (although that is actually only for the VPN access to my home network of relevance should be). Success was no approach.
Do you have a solution?
Thank you!
