TheAuditur
Sep 18, 2022Follower
Nighthawk R7000 - Goes offline multiple times a day
Recently moved into a new house, purchased a new nighthawk R7000. Internet provider has the modem on the outside of the house in a box, connected to the router is a POE. Firmware Version V1.0.11.136_...
Sep 18, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the Internet LED turn AMBER when this happens on the R7000?
Has Armor, Circle or Traffic meter been enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
