RAE1973
Jan 10, 2021Aspirant
Nighthawk R7000 - Missing Band
My Nighthawk has been a fabulous router ever since I purchased it several years ago. As of late however i noticed that when searching for wifi connections only my 2.4 ghz appears. The 5GHZ no longer ...
microchip8
Jan 10, 2021Master
Did you login into the router to see if the 5 GHz band is enabled?
- RAE1973Jan 11, 2021Aspirant
Thanks, it seems that I had applied "SmartConnect" and the router searched for the best band to use all the time. Thus the 5GHZ band was not appearing in my list of wifi connections. After unchecking "SmartConnect" the 5 GHZ band now appears in my list of available wifi connections. So, now my question is it appears 9 out of 10 devices in my home connect to the 2.4 GHZ and the 5 GHZ is hardly used by any of them when I am in "SmartConnect" mode. Should I leave it in SmartConnect mode? Is tghere any reason for me to choose which band I use since the router chooses the best connection when in SmartConnect mode?
- michaelkenwardJan 11, 2021Guru - Experienced User
If a device cannot use 5 GHz wifi it will not see it and will simply connect to the 2.4 GHz source.
Your call. Wifi clients are usually smart enough to go for the best signal they can use.
This means that you don't have to mess around picking a wifi band.
The only time when it can help to have separate SSIDs for 2.4 GHz and the 5 GHz is when you are trying to set up a crummy IoT device whose makers aren't smart enough to design an installation app that falls over when trying to use a 5 GHz connection to install a device on 2.4 GHz. In those circumstances temporarily turning off the 5 GHz SSID can be a solution.
Thanks so much, appreciate the help and advice
