sujit_singh2001's avatar
Feb 09, 2018
Nighthawk R7000 - Not able to Login to Parental Control
After I updated the firmware, I was not able to loggin to Parental Control even though I have the correct user ID and password. I then logged in to the same OpenDNS account and deleted the account. Now I created a new DNS account and when i try to login to Parental Control using the new OpenDNS account it states that my device is already registered with another account. Kindly Help. I am using Netgear Nighthawk R7000 router. I installed Netgear Genie on my Windows 10 PC and then ran the firmware update and this caused the issue i believe.
  • I also had similar issues after upgrading my Netgear Genie program on 2 separate Windows 7 PC's.
    My R7000 has the latest firmware version V1.0.9.18 and I've been running Netgear Genie Desktop version 2.4.50.  Live Parental Controls enabled and everything working as expected.  I responded to the program banner button that an upgrade is available and after the upgrade, I experienced issues with my login to OpenDNS, my bypass account login / logout was not functioning consistently or properly.  I took a number of steps to troubleshoot the issue such as:
    - resetting passwords in OpenDNS and bypass account
    - uninstalling and reinstalling latest version of Netgear Genie Desktop
    - rebooting everything
    - check on another PC after upgrade to 2.4.52, same issues
    - Check Netgear Genie Live Parental Controls on my Android device - all functioned as expected
    - Uninstall Netgear Genie and re-install old version (2.4.50).  Everything functioning normal.
    Based on this, I'm guessing there is either a bug in 2.4.52 or the upgrade / uninstall process has an issue preventing the upgrade version from functioning as intended.  I would not upgrade Netgear Genie Desktop to 2.4.52 unless you have a specific reason to do so and if you are experiencing problems, I would suggest using version 2.4.50 or restoring the version installed prior to any upgrade.
    I was looking for a way to report this as a potential bug to Netgear but there doesn't really appear to be a way to do that.
