KHeilborn
Jun 21, 2017Tutor
Nighthawk R7000 - ReadySHARE vault paused and will not resume
I Hello I have a Netgear Router R7000 Nighthawk with an USB HDD attached that I use to backup my laptop to. Problem is that the ReadySHARE vault from time to time for some reason pauses and I'm not ...
- Jul 04, 2017
Yes - I've uninstalled and reinstalled the software several times.
Since last time which was appr. a week ago it has been working though. Keeping my fingers crossed it will continue to work this time...
Best regards
/Knut
JamesGL
Jun 26, 2017NETGEAR Employee Retired
Hi KHeilborn,
What is the reason why the back up pauses? Did you encounter any disconnection from the router?
Try to uninstall and reinstall the ReadyShare Vault.
- KHeilbornJun 27, 2017Tutor
Hi
Actually I don't know why it pauses. It seems to be randomly - or at least I haven't figured it out yet.
And I have tried to uninstall and reinstall the ReadyShare Vault but then I can't reconnect the previous backup and have to start all over again.
Best regs
/Knut
- JamesGLJul 03, 2017NETGEAR Employee Retired
Hi KHeilborn,
Did you experience the same problem after reinstalling the software?
- KHeilbornJul 04, 2017Tutor
Best regards
/Knut
