KHeilborn
Jun 21, 2017Tutor
Nighthawk R7000 - ReadySHARE vault paused and will not resume
I Hello I have a Netgear Router R7000 Nighthawk with an USB HDD attached that I use to backup my laptop to. Problem is that the ReadySHARE vault from time to time for some reason pauses and I'm not ...
- Jul 04, 2017
Yes - I've uninstalled and reinstalled the software several times.
Since last time which was appr. a week ago it has been working though. Keeping my fingers crossed it will continue to work this time...
Best regards
/Knut
KHeilborn
Jun 27, 2017Tutor
Hi
Actually I don't know why it pauses. It seems to be randomly - or at least I haven't figured it out yet.
And I have tried to uninstall and reinstall the ReadyShare Vault but then I can't reconnect the previous backup and have to start all over again.
Best regs
/Knut
JamesGL
Jul 03, 2017NETGEAR Employee Retired
Hi KHeilborn,
Did you experience the same problem after reinstalling the software?
- KHeilbornJul 04, 2017Tutor
Best regards
/Knut
- JamesGLJul 04, 2017NETGEAR Employee Retired
Hi KHeilborn,
Thank you for the update. Continue to monitor and provide us feedback.
