cabwav
Jun 16, 2021Tutor
Nighthawk R7000 - throttling internet connection
Internet download speed is substantially lower that what I am getting from my ISP. When I connect my computer directly to the modem with a CAT7 certified cable, I get the full 400mbps that I pay for,...
- Jun 17, 2021
The problem is solved. It turned out that I had to reset the router to factory settings. This didn't work the first time with the router lights going crazy in various repeating configurations, but after a couple of tries including resetting the modem, I finally got Ookla to report the correct download speed.
Thank you for your help
Jun 16, 2021Guru - Experienced User
If you put the arris back in router mode (disable its wifi) and connect the R7000 in access point mode, does it hit full speeds?
it wouldn't be the first device I seen not function properly in bridge mode.
