cabwav
Jun 16, 2021Tutor
Nighthawk R7000 - throttling internet connection
Internet download speed is substantially lower that what I am getting from my ISP. When I connect my computer directly to the modem with a CAT7 certified cable, I get the full 400mbps that I pay for,...
- Jun 17, 2021
The problem is solved. It turned out that I had to reset the router to factory settings. This didn't work the first time with the router lights going crazy in various repeating configurations, but after a couple of tries including resetting the modem, I finally got Ookla to report the correct download speed.
Thank you for your help
Jun 16, 2021Guru - Experienced User
If you put the arris back in router mode (disable its wifi) and connect the R7000 in access point mode, does it hit full speeds?
it wouldn't be the first device I seen not function properly in bridge mode.
cabwav
Jun 16, 2021Tutor
Thank you for your reply. I cannot revert my modem back to 'normal' mode myself since this has to be done by my ISP. I am going to ask them to cancel the bridge mode, and I will let you know if this makes any difference.
It still puzzles me though, since I tried connecting to the modem directly to my PC and this seemed to work perfectly with the expected speed of 400mbps. So my conclusion was that the R7000 was the culprit, and not the modem. But maybe there are other considerations that I am not aware of.
- cabwavJun 17, 2021Tutor
Thank you for your help- plemansJun 17, 2021Guru - Experienced User
Eitherway, glad its working again
