Mats-cz
Mar 29, 2020Aspirant
Nighthawk R7000 + Orbi RBR50 - apps, Armor and a lot of devices... best approach?
Hi, I tried to search the community but have not found what i was looking for so if i missed something, feel free to just point me to the right thread... I have a 2 floor house, wooden. approx 1...
- Apr 05, 2020
To sum up this thread for any future useage:
You can find best setup in the following links in regards to Orbi:
https://www.tech21century.com/netgear-orbi-questions-and-answers/
https://averagetechblog.com/how-to/netgear-orbi-settings/
After review of several sources and chat within this thread, it seems having the router (R7000) as router is the best thing but disable the wifi of the router. Use Orbi as main Wifi-connector!
If you can, then connect Orbi by cable to the router, disable daisy-chain in Orbi RBR50 unless you have 3 satellites or more OR have in a chain situation like RBR - Sat - Sat approach... and if you have them connected by wore / cable to the router you should not need to have daisy chain either...
So, above are my findings after a lot of reviews and questioning.
Netgear Armor has for me been very useful, covering unlimited devices. The portal is still a bit "crappy" but finctionality remains good. Both Orbi as well as the R7000 can enable Netgear Armor for you.
If you want to use teh Nighthawk APP you need to enable and connect to the Nighthawk wifi (i set up a small "admin SSID" that i use now and then but disable it, when in "normal use".
Also, please note - my R7000 did NOT find the latest firmware that was released in early April. I had to update manually to close the security flaw. Might be useful to know!!
michaelkenward
Mar 30, 2020Guru - Experienced User
Add more Orbi satellites?
- Mats-czMar 30, 2020Aspirant
Hmm.. i was expecting the reply to be tagged to the post i hit reply to but it seemed to end up further below...
Anyway, with reply to this one:
Most likely a good suggestion assuming it would help. Would you think that it is the number of devices causing issues? No real chnages has been added to the house apart form more devices of course. Or would you deem outside interference if neighbours step up their game in "stronger wifi"?
And if i add more Orbi's, would it make sense to ditch the R7000 totally or is it a better router than the Orbi?
michaelkenward wrote:Add more Orbi satellites?
