wigglemonster
Sep 26, 2018Aspirant
Nighthawk R7000 AC1900 - latency / ping issues
Router Info:
FW Version: V1.0.9.34_10.2.36
Symtpom Description:
All internet connections have latency go from a normal sub 30ms to > 500ms. The spike usually lasts for about 5 seconds and goes back to normal for about 30-40 seconds then back up again and so on.
Tests completed:
- I have attempted to monitor the latency on multiple devices, wired and wireless and they all show the same issues described above.
- I have plugged directly into my modem and the issue does not occur (very steady connection)
- I have turned all settings back to default on the router, issues persist
- After unplugging and plugging back in the issues go away for a while (up to 5 hours or so) then come back
Looking for advice on next steps.. thanks.
Turns out the modem was the issue..
- wigglemonsterAspirant
Bumping this.. Hoping for some help!
- myerswMaster
Thanks for the update for solution of problem. May help someone else.
