Esbeuu's avatar
Esbeuu
Follower
Oct 19, 2022
Nighthawk R7000 AC1900 - WiFi Randomly Drops on Devices
Hello,
I recently bought the Nighthawk R7000 AC 1900 and the last couple of days I have noticed that devices will lose internet connection randomly.  Some will stay connected, some will drop.  Any solutions to this problem?
Thanks!
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What wireless devices do you have connected?
    How is the routers wifi configured on the Basic and Advanced WIFI settings menus?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
  • michaelkenward's avatar
    michaelkenward
    Esbeuu wrote:
    .... the last couple of days I have noticed that devices will lose internet connection randomly.  Some will stay connected, some will drop.
    What do you see when this happens?
    Tell us a bit more about your set up and where you see signs that these wifi clients lose their connection.
    Wifi is two-way process. You need to pin down where the fault lies.
