DavidHoang's avatar
DavidHoang
Nighthawk R7000 AC1900 firmware corrupted
My Netgear R7000 AC1900 just got problems on firmware again ( Power light flashing continuously). Reset did not help. I have tried to install firmware via TFTPD64 ( last time I reinstalled firmware was working well), but this time LAN port does not communicate or fail ( Message on PC showing unplugged, Ping on CMD unreachable). How to solve this problem. Thanks for helps!
  • > [...] Power light flashing continuously [...]
       You may be a candidate for the TFTP recovery scheme.  See, for
    example:
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
    > [...] I have tried to install firmware via TFTPD64 [...]
       No third-party software is required.  Windows includes a TFTP program
    (although you might need to enable it).
    > [...] LAN port does not communicate or fail ( Message on PC showing
    > unplugged, Ping on CMD unreachable). [...]
       Too vague to be a useful problem description.
       The TFTP recovery scheme is a multi-step procedure which offers
    multiple opportunities for user input, hence user error.  By itself,
    saying that you "tried" it doesn't say much.  As usual, showing actual
    actions (commands) with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.  Especially when using a command-line program,
    copy+paste is your friend.
    • DavidHoang's avatar
      DavidHoang
      Thanks alot for your comments Antinode.
      Here with what i did:
      I use 3rd party tfdp64.exe soft.
      Used cmd to ping rounter: ping 192.168.1.1
      reply from 192.168.1.10 is unreachable. I think that may be the reason why i can not install the firmware
      • antinode's avatar
        antinode
        Guru
           > Used cmd to ping rounter: ping 192.168.1.1
        > reply from 192.168.1.10 is unreachable. [...]
           Ok.  The computer is at "192.168.1.10"?
        > [...] I think that may be the reason why i can not install the
        > firmware
           If "ping" fails, then there's not much hope for TFTP.
           I'd try playing with power-on and Reset, to see if I could find a
        way/time to catch it with "ping" working" and/or a TFTP server running.
        > [...] LAN port does not communicate [...]
           Does the LAN port-status LED on the R7000 show a good physical link?
           While we're here, which file did you intend to send?
