DavidHoang
Mar 18, 2021Aspirant
Nighthawk R7000 AC1900 firmware corrupted
My Netgear R7000 AC1900 just got problems on firmware again ( Power light flashing continuously). Reset did not help. I have tried to install firmware via TFTPD64 ( last time I reinstalled firmware wa...
DavidHoang
Mar 19, 2021Aspirant
Thanks alot for your comments Antinode.
Here with what i did:
I use 3rd party tfdp64.exe soft.
Used cmd to ping rounter: ping 192.168.1.1
reply from 192.168.1.10 is unreachable. I think that may be the reason why i can not install the firmware
antinode
Mar 19, 2021Guru
> reply from 192.168.1.10 is unreachable. [...]
Ok. The computer is at "192.168.1.10"?
> [...] I think that may be the reason why i can not install the
> firmware
If "ping" fails, then there's not much hope for TFTP.
I'd try playing with power-on and Reset, to see if I could find a
way/time to catch it with "ping" working" and/or a TFTP server running.
> [...] LAN port does not communicate [...]
Does the LAN port-status LED on the R7000 show a good physical link?
While we're here, which file did you intend to send?
- DavidHoangMar 19, 2021AspirantYes, the computer ip address is 192.168.1.10
I have done many reset, but it there were no luck.
Power on and off many times did not help.
All lights are flashing, no signal showed that LAN ports are working
