Parker98
Jul 15, 2017Aspirant
Nighthawk R7000 AC1900 Only allowing certain machines to see Readyshare
Having a crazy problem with my Nighthawk R7000 AC1900 Router. It is on a Uninterruptable Power Supply, but we have had some power interruptions in recent days. Everything was working fine. I upgrade...
- Aug 30, 2017
Thanks for reply. I figured it out. When the firmware was upgraded it set the Workgroup back to default name Workgroup. When I restored the correct name the problem went away.
Parker98
Also rebooted machines and router.
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi Parker98,
Please try this.
1. Go to Control Panel > User Accounts > Manage Windows Credentials
2. Add a Windows Credential
3. Enter the directions to the router and the router's user name and password. See example below:
\\readyshare
admin
password
4. Click on OK
5. Check to see if you are able to access the drive via Windows Explorer
- Parker98Jul 20, 2017Aspirant
Unfortunately didn't work. Something really crazy because any machine that wasn't on when the problem started boots up and connects. Just two machines one a laptop and one a desktop won't connect to readyshare.
- IrvSpJul 20, 2017Master
Parker98 wrote:Unfortunately didn't work. Something really crazy because any machine that wasn't on when the problem started boots up and connects. Just two machines one a laptop and one a desktop won't connect to readyshare.
Possible the machines that were on suffered some file corruption when they lost power? Try deleting the READYSHARE references and rebuilding them (including the certificates).
