InThisSituation
Dec 04, 2020Aspirant
Nighthawk R7000 AC1900 Throttling my Connection From 1gb to Barely 400mb
Hi All, I recently upgraded my residential Comcast internet service to 1gb (40mb up). The new Motorola DTE we purchased is working as expected (it's even primed for Docsis 4.0), but the R7000 ref...
InThisSituation
Dec 05, 2020Aspirant
"What you could try before a reset would be to disable access control, parental controls, traffic monitoring, and qos. Once disabled, reboot the router."
- None of those were enabled to begin with.
Current firmware version:
V1.0.11.110_10.2.100
Dec 05, 2020Guru - Experienced User
If there were ever enabled, a factory reset it worth a shot.
If that doesn't help, then I'd try downgrading to version 1.0.9.42 of the firmware. Then factory reset and clean reinstall (not from a backup configuration).
- InThisSituationDec 05, 2020Aspirant
Tried that. No difference.
