InThisSituation
Dec 04, 2020Aspirant
Nighthawk R7000 AC1900 Throttling my Connection From 1gb to Barely 400mb
Hi All, I recently upgraded my residential Comcast internet service to 1gb (40mb up). The new Motorola DTE we purchased is working as expected (it's even primed for Docsis 4.0), but the R7000 ref...
Dec 05, 2020Guru - Experienced User
If there were ever enabled, a factory reset it worth a shot.
If that doesn't help, then I'd try downgrading to version 1.0.9.42 of the firmware. Then factory reset and clean reinstall (not from a backup configuration).
InThisSituation
Dec 05, 2020Aspirant
Tried that. No difference.
- plemansDec 05, 2020Guru - Experienced User
did you do a factory reset and clean install? make sure not to use a backup configuration
what modem model number is it?
- InThisSituationDec 05, 2020Aspirant
A Motorola MB8600.
