MOKYO22
Sep 16, 2022Aspirant
nighthawk r7000 ac1900
hi- my router is 5 yrs old. i see today.......my internet speed has jumped wayyyyyyyyyyy down......... thought it was my isp,it is not. i disconnected the router from the ...
Sep 16, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
MOKYO22
hello furrrry- thx 4 reply
firmware- v1.0.11.126, cat 5 cables........original with nighthawk unit, spectrum modem- mfg is arris # tm1602
no factory reset done. yes, unplugged modemrouter ,plugged back in,proper sequence/time.............same thing.
speed is fast w/o nighthawk in the loop. back in,back to slow....................thx,m
- FURRYe38Sep 16, 2022Guru - Experienced User
I would upgrade to CAT6 between modem and router.
Factory reset and setup from scratch with out enabling Armor, Circle or Traffic Meter.
Also might try upgrading FW as well:
- MOKYO22Sep 16, 2022Aspirant
factory reset did it.................................cant find a good download for genie-pc....................flips over to nighthawk app.
- michaelkenwardSep 17, 2022Guru - Experienced User
genie | Product | Support | NETGEAR
