MOKYO22
Sep 16, 2022Aspirant
nighthawk r7000 ac1900
hi- my router is 5 yrs old. i see today.......my internet speed has jumped wayyyyyyyyyyy down......... thought it was my isp,it is not. i disconnected the router from the ...
MOKYO22
hello furrrry- thx 4 reply
firmware- v1.0.11.126, cat 5 cables........original with nighthawk unit, spectrum modem- mfg is arris # tm1602
no factory reset done. yes, unplugged modemrouter ,plugged back in,proper sequence/time.............same thing.
speed is fast w/o nighthawk in the loop. back in,back to slow....................thx,m
Sep 16, 2022Guru - Experienced User
I would upgrade to CAT6 between modem and router.
Factory reset and setup from scratch with out enabling Armor, Circle or Traffic Meter.
Also might try upgrading FW as well:
- MOKYO22Sep 16, 2022Aspirant
factory reset did it.................................cant find a good download for genie-pc....................flips over to nighthawk app.
- michaelkenwardSep 17, 2022Guru - Experienced User
genie | Product | Support | NETGEAR
- MOKYO22Sep 17, 2022Aspirant
hi.............saw that.........it downloads fine............try to open file???? opens window, little circle keeps spinning..........wont open?
windows 11. and- since i did hard reset. cant access genie password at router settings?????
admin is there,next is password..........i tried default,nope..........and the 2 passwords i had since bought unit.........nope
dont think im gonna reset again................not worth the time/frustration..................thx
- FURRYe38Oct 03, 2022Guru - Experienced User
I believe Genie is being depreciated and not supported anymore. It's the Nighthawk app for mobile devices that can connect to the router and use a PC or laptop and web browser to connect to the routers web page. If you factory reset the router and setup from scratch using a PC and web browser. After the router is setup, then you should be able to connect to the router using the Nighthawk app.
