mdculp
Feb 22, 2019Aspirant
Nighthawk R7000 All LAN and the WAN Ports Quit Working
Router was working fine and had no issues, but one day all the ethernet ports stopped working. The WAN port will not link to the cable modem and plugging the ethernet cables in does nothing. The wire...
- Feb 22, 2019
Perhaps the ports are just toast from some sort of an electrical surge/spike or some sort of internal failure.
If you've tried factory reset multiple times and can't connect to it then, unfortunately, it may be for the scrap pile. Best I got...
Whoaru99
Feb 22, 2019Apprentice
mdculp
It very well could have been an electrical surge from a lightning strike about a month before it quit. It was extremely close and took out a cable box and television. Maybe it just took it a month to give up the ghost. Thanks for the response.
