mdculp
Feb 22, 2019Aspirant
Nighthawk R7000 All LAN and the WAN Ports Quit Working
Router was working fine and had no issues, but one day all the ethernet ports stopped working. The WAN port will not link to the cable modem and plugging the ethernet cables in does nothing. The wire...
- Feb 22, 2019
Perhaps the ports are just toast from some sort of an electrical surge/spike or some sort of internal failure.
If you've tried factory reset multiple times and can't connect to it then, unfortunately, it may be for the scrap pile. Best I got...
myersw
Feb 22, 2019Master
If within the support window, contact support for a replacement. Netgear Ethernet ports seem to be tender for some reason.
mdculp
Feb 23, 2019Aspirant
Unfortunately, I bought it from someone that couldn't use it after they bought it. They had already registered it though. I only gave $50 for it, so no big deal. Just hate to toss it when a buck fifty capacitor will probably fix it.
- microchip8Feb 23, 2019Master
if you're shopping for a new router and want to stay with NETGEAR, I highly recommend to look at the R7800. It's one of the few models NG has that tends to have few issues
