jerry8989
Dec 23, 2021Tutor
Nighthawk R7000 always redirects to 192.168.1.1/genie_index.htm
Hello, My router wasn't used for a long time and I took it out to use at my parents house and I reset it and reloaded the oldest firmware (V1.0.0.96_1.0.15), so then I can upgrade to the latest firm...
- Dec 23, 2021
Yes, That was the issue. I figured it out. When it asks if I want the Genie to set it up I was saying yes, but this time I chose "No" to set it up myself and it let me into the admin section. I was able to download the latest firmware and install it and it just restarted and it looks good.
Thank you everyone for your help.
Jerry
Dec 23, 2021Guru - Experienced User
Try a different browser?
Factory reset the router and setup from scratch using a web browser at 192.168.1.1.
jerry8989
Dec 23, 2021Tutor
Thank you Furry,
I have tried resetting the router from the back for the 30-30-30 and I tried chrome, firefox and edge and they all redirect me to the genie which checks for internet connection. It's so weird because I was able to downgrade the firmware from the screens I'm looking for, but they won't come up again.
- microchip8Dec 23, 2021Master
I do not have a solution for you as this is the first time I've heard of such a behavior. Just want to note that a 30-30-30 reset does not work on ARM-based routers. Only MIPS ones.
- jerry8989Dec 23, 2021Tutor
Thank you for the heads up.
It's so weird, I just want to reset it completely to how it was the day I bought it and then upgrade to the latest working firmware.
- FURRYe38Dec 23, 2021Guru - Experienced User
10 second press of the reset button and release for NG routers is good enough.
So is the wizard not getting past the checking internet connection?
