jerry8989
Dec 23, 2021Tutor
Nighthawk R7000 always redirects to 192.168.1.1/genie_index.htm
Hello, My router wasn't used for a long time and I took it out to use at my parents house and I reset it and reloaded the oldest firmware (V1.0.0.96_1.0.15), so then I can upgrade to the latest firm...
- Dec 23, 2021
Yes, That was the issue. I figured it out. When it asks if I want the Genie to set it up I was saying yes, but this time I chose "No" to set it up myself and it let me into the admin section. I was able to download the latest firmware and install it and it just restarted and it looks good.
Thank you everyone for your help.
Jerry
Dec 23, 2021Guru - Experienced User
10 second press of the reset button and release for NG routers is good enough.
So is the wizard not getting past the checking internet connection?
jerry8989
Dec 23, 2021Tutor
Jerry
- FURRYe38Dec 23, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- jerry8989Dec 24, 2021Tutor
Thank you Furrye38, I will do a backup.
I appreciate the help.
