afcbmike's avatar
afcbmike
Nighthawk r7000 and app
I am having issues with Ubisoft. Long story short they want me to port forward. I had to hard reset the router some time ago. Now, I use the app and I cannot connect to the network of the router. I am connected to the correct wifi connection and the app sees it but says I am disconnected. I am not sure how to solve this.
Every time I go to routerlogin.net I am redirected to the Netgear website and it cycles around.
  • plemans's avatar
    1. what firmware is on the router?
    2. what gateway/modem is the router connected to?
    3. does the IP address of the router work?
    4. why does ubisoft think you need to port forward?
    • afcbmike's avatar
      afcbmike
      1. I don't know as I can't access the router
      2. How do I find it out?
      3. Is it 192.168.1.1? If so, then no. It times out.
      4. Because I can't access AC Valhalla add-ons on my PS5 despite no other problems with anything at all
      • plemans's avatar
        afcbmike wrote:
        1. I don't know as I can't access the router---
        2. How do I find it out?----follow the little wire thats plugged into the wan port of the router. That'll lead back to something with a model number on it.
        3. Is it 192.168.1.1? If so, then no. It times out.---it might have changed if your gateway is a combo device.
        Your router might have used a different ip address if it detected a double nat (cascading routers) issue. its why we ask.
        Try disconnecting the router from the modem, reboot the router, connect a pc/laptop to the router. then pull up a command prompt and type "ipconfig"  the default gateway is the routers ip address.
