johnwmcc
Oct 09, 2021Aspirant
NightHawk R7000 and GS 105 and GS108 switches connection problems
I'm using three Netgear devices on a Virgin Media cable modem internet connection. I've recently had short unplanned (1/2-1hr) power outages while I was having smart meters fitted, and independen...
- Oct 11, 2021
Well, things are gradually improving.
I have basically had to rebuild my network almost from scratch.
Most devices are now up and running again, and the switches appear to be working normally for wired connections.
What I think happenedk was that after the power cut, devices started up before the router was fully operational, and I think before the address reservations set in the router took effect.
As I brought devices back up gradually, I think the automatic assignment of IP addresses would have prevented duplicate IP address assignment.
But I am still disappointed that the existing reserved IP addresses seem NOT to have been followed in full. Or else I'm misunderstanding which screen actually does the reservations.
Anyway, I'll continue switching on the remaining wireless devices, now I have the wired network working properly again, as far as I can tell so far.
Oct 11, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Or try the Switch forum if you feel this is a problem with the switch"
https://community.netgear.com/t5/Unmanaged-Switches-Forum/bd-p/business-unmanaged-switches
Thank you.
- johnwmccOct 11, 2021Aspirant
Thanks for the suggestion to move it to the NightHawk category.
Not being familiar with this forum, I'm not sure how to do that - can I do it myself? If so, how.
If not, can some moderator do it for me?
Thanks for the suggestion.
The switches appear to be working now - I think conflicting IP addresses is the most likely cause of the issue.
