jodecluette
Oct 25, 2019Aspirant
NightHawk R7000 and OpenVPN on Windows 7 and 10 openvpn error 868
I have been trying to get the vpn service setup and working on the Nighthawk R7000 with clients in Windows 7 and Windows 7, I have followed the setup and check and re-checked everything appears okey....
- Oct 26, 2019
Okey, maybe I'm not explaining myself so I'll try again, I have already gone throught the netgear setup and tested the install and the router and my computer say it is connected and functioning.
I cannot connect from any outside device not my phone, not my laptop running on a seperate internet and even my desktop running on a seperate internet so please don't provide a link to the netgear vpn setup. I am trying to connect to the vpn without success.
Maybe this will help I used the netgear ddns service which gave me a host name to use, a port id, do I create a new user name and password for the vpn or do I use the login for my desktop or can I not use the host name provided by ddns service that was provide by netgear?
Thank you for the help
Badock
Oct 26, 2019Tutor
Okay, there's a lot to this.
You'll need a Dynamic DNS service to keep track of your router's WAN IP so you'll be able to find it when you're out and about if it changes. Unless you have a static IP that is, and almost no one does.
This is a tutorial on setting up VPN with Netgear routers.
Again, if you are attempting to connect to the Netgear router VPN, I doubt that it will work if you are on a computer connected to the internal LAN. I beleive that it only accepts connections from the WAN port. To test, put a VPN client on your phone, disconnect it from the wifi and use the phone to connect. That will come into the router from the internet via your cellular provider.
jodecluette
Oct 26, 2019Aspirant
- jodecluetteOct 28, 2019Aspirant
For you guys out there that are like me and trying to setup netgear vpn for the first time and using the No-IP DDNS service please note: The netgear setup instructions provided in incomplete, after creating a DDNS user account netgear provide you with a host name. If you want to use the host name you must and I repeat you must login at No-IP and activate that host name are it will not work. Please make sure you have the complete set of instructions before you advise others on what to do when they ask for assistant.
Thank you for your help and I do apologize if my words have offended anyone.
