Hurly225
Jan 14, 2017Tutor
Nighthawk R7000 and Readyshare USB printer problem
My HP9800 printer worked fine for the first months on the Nighthawk AC1900 via the USB port. Then it started to give me headacke... First it would (somtimes) only print the last page of a printjob. A...
- Jan 29, 2017
In my case, resetting the r7000 fixed the bojour print problem. I'm able to print again from mac, windows, other unix systems. even while re-configuration by hand did take some time as I don't tried to safe the config prior to reseting and restoring the settings with the backuped settings file (i guessed that this will not work).
Hurly225
Jan 15, 2017Tutor
I suspect that the problem(s) came after updating the Nighthawk R7000 router, so maybe Netgear would be so kind to try to fix this bug.
I say this because the setup with the printer attatch via the routers USB port worked fine for several months before not being able to wakeup or reattatch to the printer automaticly whenever i send a printjob to the printer
multisaft
Jan 15, 2017Initiate
Same issues here.
attached to my r7000 is a brother hl-2140 via usb connection and since the last update to V1.0.7.6_1.1.99, readyshare usb isnt able to print anymore from win10 or os x 10.11.6 or 10.12.
plz netgear, fix your bonjour driver!
- JamesGLJan 15, 2017NETGEAR Employee Retired
Hi All,
If you have not tried to reset the router to factory default after the update, please try it and manually reconfigure.
- JamesGLJan 18, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Hurly225Jan 18, 2017Tutor
Did not try the factory reset, setting it up again will take some time, maybe i will one day but i daut it´ll fix the problem.
I did though find out that:
If i "EXIT" the USB Control Center correctly by choosing "System" and then "Exit" end then restart the USB Control Center again before i want to print somthing, then the printer is found and i can connect to the printer again.
At least it´s quicker than deleting and reinstalling the printer itself. But i dident have to do this in the first months when i started to use this setup. Somehow the USB Control Center automaticly scaned the network for USB printers attatch to the router and automaticly connected to it when ever i needed it. So something has changed.
Don´t know if i would call this a solution, but it´a way for me to work around the problem until a more sustainable solution is implemented in either the router or USB Control Center.
- Hurly225Jan 19, 2017Tutor
BTW, it seems that for some printjobs, maybe limited to printing pdf´s, only the last page in the printjob gets printed. And it´s rather timeconsuming to print one page at a time....
Been thinking that maybe i should buy a printserver or a network printer, dosen´t looks like the USB setup via the R7000 will work in a satisfactory manner, unless Netgear finds out what coursing theese problems
