Hurly225
Jan 14, 2017Tutor
Nighthawk R7000 and Readyshare USB printer problem
My HP9800 printer worked fine for the first months on the Nighthawk AC1900 via the USB port. Then it started to give me headacke... First it would (somtimes) only print the last page of a printjob. A...
- Jan 29, 2017
In my case, resetting the r7000 fixed the bojour print problem. I'm able to print again from mac, windows, other unix systems. even while re-configuration by hand did take some time as I don't tried to safe the config prior to reseting and restoring the settings with the backuped settings file (i guessed that this will not work).
multisaft
Jan 15, 2017Initiate
Same issues here.
attached to my r7000 is a brother hl-2140 via usb connection and since the last update to V1.0.7.6_1.1.99, readyshare usb isnt able to print anymore from win10 or os x 10.11.6 or 10.12.
plz netgear, fix your bonjour driver!
JamesGL
Jan 15, 2017NETGEAR Employee Retired
Hi All,
If you have not tried to reset the router to factory default after the update, please try it and manually reconfigure.
